I upgraded to the latest version of PWB PWB3036g
in my INI, this is set,
[Buttons]
Compatibility=True
but the button doesn't show.
I reverted back to the older version and the button is there again.
Can you fix it?
Compatibility Mode Button
Re: Compatibility Mode Button
Set the following in the INI file to enable the Compatibility mode button PWB 3.03.6.
[Buttons]
Compatibility=Compatibility
[Buttons]
Hi, thanks for the fix. Unfortunately, when the compatibility button is enabled, it groups together with the Home button into a dropdown menu (see pic). Could we get them to separate so they're extended across the toolbar? Thank you.
- PWB.png (66.84 KiB) Viewed 7939 times
Set the Navigation Bar Width to meet your needs.
[Toolbars]
NavigationBarWidth=500
[Toolbars]
Ah, thank you! All is well now.
