Problems with Flash in PWB 3 CEF
jdonovan
Post by jdonovan »
We opened a new library, and set the PCs up to use PWB 3 CEF with Chrome Version 41.0.2272.89 m.
Users have been experiencing issues getting to http://yourtexasbenefits.com, among other places.
It either does nothing, or tells them that they need to update Flash
Left is through PWB, right is Chrome Version 41.0.2272.89 m
Chrome Flash.jpg (246.44 KiB) Viewed 15115 times
It works fine in Chrome and IE 11, just not in PWB.
Any thoughts?
jdonovan
Re: Problems with Flash in PWB 3 CEF
Post by jdonovan »
In PWB, it's saying Flash is installed, but disabled.
But, in the plugins on Chrome, it's set for always allowed.
What version of PWB v3 CEF are you using including the minor revision number, for example 3.04.2?
jdonovan
Post by jdonovan »
It's 3.0.4.1
Did you try re-installing Flash?
jdonovan
Post by jdonovan »
I did, but it never goes through.
It never installs, or it is not reported by the web site?
If you run IE does it report Flash is installed?
jdonovan
Post by jdonovan »
it never installs.
But, it's working fine in both IE and Chrome
The Chrome browser uses it own internal Flash based player. At this point in time the CEF HTML rendering engine uses the install-able version of Flash from Adobe.
Are you getting any errors when installing Flash?
Try using the Flash Stand Alone installer.
https://www.adobe.com/support/flashplay ... loads.html
jdonovan
Post by jdonovan »
That looks like it may help. I'm rolling it out to some of the affected computers for testing.
