SirsiDynix "Click anywhere to return home" message
The SirsiDynix Library catalog home page has a 30 minute session timeout resulting in a message that may confuse patrons. This is coming directly from the webpage and is not a PWB message.
Using the power of PWB we can inject JavaScript into the page to refresh it every 25 minutes.
Add/Change the following in your PWB INI file:
JavaScriptFilterFile=sirsifilter.txt
CheckJavaScriptAccess=True
Download the attached files:
sirsiscript.txt
(61 Bytes) Downloaded 170 times
sirsifilter.txt
(69 Bytes) Downloaded 185 times
The "sirsifilter.txt" will look for the "https://stan.ent.sirsi.net/client/en_US/cer" URL, and when found will inject the "sirsiscript.txt" file.
-all
+^https://stan.ent.sirsi.net/client/en_US/cer	sirsiscript.txt
The "sirsiscript.txt" file adds a 25 minute timer that refreshes the page. This will reset the SirsiDynix 30 minute session timeout.
setTimeout(function() {
  location.reload();
}, 1500000);
