MSN & Yahoo Messenger Toolbar Buttons
ramone_johnny
Post by ramone_johnny »
Hi guys,
Is there any way of allowing the messenger buttons within the toolbar of PWB. Id much prefer this if possible rather than having desktop icons, as the shell has been replaced.
John
PWB does not support IE Browser Helper Objects as this is a function of the IE User Interface and not the HTML Rendering Engine PWB uses.
You should be able to put the Messenger Shortcut on the PWB Shellbar.
Scott wrote:You should be able to put the Messenger Shortcut on the PWB Shellbar.
Err...how would this be done?
John
Enable the Shellbar.
ShowShellbar=True
Create a shortcut to MS Messenger (msmsgs.exe), usually found in the C:\Program Files\Messenger folder and put the shortcut in the Shellbar folder.
ShellBarFolder=ShellBar
This will place a button on the Shellbar that launches MS Messenger.
Thanks Scott, we got this working yesterday.
Cheers! :D
John
