Account information auto filled in
cooperf01
Participant
Participant
Post by cooperf01 »
Is there a way to fill in the information needed for login to a specific web page automatically so all the have to do is click log in.
Re: Account information auto filled in
See this topic in the forums "PWB CEF Autologin to a Site":
viewtopic.php?f=8&t=3652
cooperf01
Participant
Participant
Post by cooperf01 »
I have tried that but it does not seem to work. This is the URL for the site https://seminolestate.campus.eab.com/se ... irect=true and I added the signinfilter.txt to the end but it does not work.
If the following values are not present, add them to your INI file.
JavaScriptFilterFile=signinfilter.txt
CheckJavaScriptAccess=True
In the filter file (signinfilter.txt):
-all
+^https://seminolestate.campus.eab.com/session/new	signinjavascript.txt
In the JavaScript file (signinjavascript.txt):
document.getElementById('login').value='john';
document.getElementById('password').value='letmein';
document.getElementsByName('commit')[0].click();
The filter file has PWB analyze each URL, specifically for one that starts with "https://seminolestate.campus.eab.com/session/new", and when it matches inject the JavaScript from the "signinjavascript.txt" file.
This will fill in the "login" element with "john" and the "password" element with "letmein" and then click the "commit" element.
Notice we had to use the get element by name in the second command as the "commit" element does not have an ID.
Here are the files we tested with.
(153 Bytes) Downloaded 765 times
signinfilter.txt
(79 Bytes) Downloaded 769 times
PWB.INI
(6.57 KiB) Downloaded 756 times
cooperf01
Participant
Participant
Post by cooperf01 »
Thank you.
