Compatibility Mode
Posted: Mon Aug 05, 2013 3:23 pm
by Sachem
Would it be possible to add an option in the .ini to render the page with compatibility mode on?
We have a few sites that since the upgrade to IE10 wont load properly without compatibility mode. We have separate ini files for each shortcut so if we could set compatibility mode in the ini it would be very helpful.
Thank you!
Re: Compatibility Mode
Posted: Tue Aug 06, 2013 8:20 am
You can set PWB v3 in Compatibility mode by adding the following to the INI file.
IEBrowserEmulation=9000
You can also use the IE Compatibility list for individual web sites. See the following post.
http://www.teamsoftwaresolutions.com/fo ... f=4&t=1449
