ReCaptcha Support
Posted: Thu Aug 06, 2020 11:52 am
by JGonzales55
I am working on setting up a PWB as a public kiosk in our lobby to allow the public till fill out record request forms without speaking to staff. I am seeing an error when loading the form about recaptcha is not supported? I am using the CEF version of PWB and have enabled external Java. I did not download and install java separately from what is included in PWB.. What steps should I try to fix this?
Link to form:
https://eagleid.justfoia.com/Forms/Laun ... 86c5a87deb
Re: ReCaptcha Support
Posted: Thu Aug 06, 2020 2:13 pm
Where is the captcha displayed?
When comparing PWB CEF 3.05.8 with Chrome they look the same.
- record.jpg (155.72 KiB) Viewed 9020 times
Posted: Thu Aug 06, 2020 3:11 pm
by JGonzales55
Thank you for the quick reply. My understanding is that the Captcha error is at the very bottom of the page and the captcha is a "silent" captcha. In testing when filling out the necessary fields and hitting submit it doesn't submit. You are more than welcome to submit a test if you would like.
I'm guessing this has something to do with scripts running in the background.
- IMG_0170.jpg (38.42 KiB) Viewed 9018 times
Posted: Thu Aug 06, 2020 3:33 pm
I see it is after the request is submitted. We did not submit the request the first time.
We are seeing the same error now. We will see if we can figure out why it is not working.
Posted: Thu Aug 06, 2020 3:38 pm
Is it going to cause an issue if we submit this request several times?
Posted: Thu Aug 06, 2020 3:46 pm
Using at least PWB CEF 3.05.8 set/add the following in your INI file.
CheckUserAgent=True
Posted: Thu Aug 06, 2020 4:11 pm
by JGonzales55
I added that to the config and it is working like a dream now! We appreciate your quick and helpful support!
Posted: Thu Aug 06, 2020 7:10 pm
Excellent.
Please let us know if we can be of any further assistance.
