I want to allow access to some some cdrom products I've installed on the hard drive. They use html indexes to access the data.
One of the links is c:/mitchell/m1domeng/index.htm
I can access them using the following url.txt but this leaves the c: wide open.
+c:
-all
+www.ondemand5.com
+www.ondemand5.com/odweb.asp
+www.ondemand5.com/login/ipauthwelcome.asp
+www.ondemand5.com/mric/mric.asp
I've tried adding the link
+c:/mitchell/m1domeng/index.htm and removing the +c: and am denied access.
I've tired various combinations of +c:/.... with no luck.
Is there any way to permit access to certain files on the hard drive while denying access to others?
Accessing *.htm files on hard drive
