PWB filters
northbayteky
Re: PWB filters
Post by northbayteky »
Scott wrote: Wed Nov 20, 2013 12:01 pm "-all" denies all URLs unless a URL is specifically allowed with "+".
You could also use the [Security]OnlyAccessHTTP=True or [Security]OnlyAccessInternet=True.
We used to use a pac file and point IE to it. I've taken a text version of the pac file which contains all the allowed URLs. Should I start with -all and then the list of allowed URLS with the + in front of each?
If I construct the URL file that way, will the allowed URLs be limited? Here's an example of some of the URLs in the list:
referenceusa.com
abcmouse.com
ancestrylibrary.com
amazonaws.com
quipugroup.net
fliphtml5.com
consensu.org
In other words, will this allow all the pages within each domain allowed? Will I need to all +all in front of each domain?
Re: PWB filters
"-all" assumes all URLs will be denied, "+all" assumes all URLs will be allowed.
If you are trying to limit PWB to a specific set of URLs start with "-all".
-all
+referenceusa.com
+abcmouse.com
+ancestrylibrary.com
+amazonaws.com
+quipugroup.net
+fliphtml5.com
+consensu.org
northbayteky
Re: PWB filters
That did it. You are awesome :-)
northbayteky
Re:
Scott wrote: Wed Dec 10, 2003 8:57 am If you are using the URL filter to prevent access to the C drive with -C:\\ in your filter file, you may have trouble if a web site attempts to use the Internet Explorer internal web resources such as the cancel page. You may want to add the resource into your URL filter file before the -C:\\.
+res://c:\windows\system32\shdoclc.dll/navcancl.htm
-C:\\
This will prevent an error if the web page tries to access the resource. Make sure your path is correct, or shorten the URL to +res://.
Never mind!
I tried adding the +FileName.html to the URL file and that worked.
northbayteky
Re:
Scott wrote: Tue Oct 21, 2003 8:34 am...
For example, old URL file
-C:\
-D:\
Convert to:
-C:\\
-D:\\
Well this just confounded me for the last few hours. We have a "special" setup in which the home page is just an html file with two links. I kept getting access denied. When I changed the entry to +C: (no backslash) the local html page finally displayed.
Of course YMMV, but I wanted to add my experience as a possibility.
