Issues with Webmail in PWB CEF v3
Re: Issues with Webmail in PWB CEF v3
For the zoom, we had to strike a balance between IE and CEF because the CEF version can open IE windows. In IE the zoom is percentage based with 100% being normal, with CEF the zoom is a number based with 0 being normal.
You are welcome. We are very proactive because if one Library is having an issue it won't be long before we have the same issue, and other Libraries report the issue.
Rockhard
Post by Rockhard »
We seem to be unable to add any attachments through Webmail when opening up in the Chrome Frame.
In Webmail, I select new, and a window pops up for me email, but when I click on the attachment icon (paperclip) It looks like there is a popup for a second then it closes again. So users are not able to add any attachments.
Any ideas what the cause of this could be?
What webmail site are you using?
Test the webmail site with an unedited INI file to determine if there is a configuration issue.
Rockhard
Post by Rockhard »
We are using Outlook Web Access 2010
Tested with an unedited PWB file, and still getting the same issue.
What version of PWB are you using including the minor revision number, for example "3.04.5"?
Rockhard
Post by Rockhard »
PWBv3050k
PWB 3.05.0K CEF seems to work without issue on our OWA Site with an unedited INI file.
Do you have Chrome Installed on the computer?
What is the path to the folder is PWB installed in?
Rockhard
Post by Rockhard »
No we do not have Chrome installed on the computers.
We are running this on Windows 7
And the PWB folder location is: \\fileserver1\apps$\PWB\GGH-OFFICE2010-URL, however we also tried it locally at location: C:\PWB\GGH-OFFICE2010
Same issue.
You should try installing Chrome on the computer in order to gain the Chrome plug-ins for PWB to use.
I assume the computer is for public access, if you run PWB on a computer that is not for public access that has Chrome installed, does the OWA site work as expected?
