CheckNet/Batch Files & PWB ShellBar
joechummer
Post by joechummer »
I currently have CheckNet starting PWBv2. However, when PWB opens, none of the links in the ShellBar show up. The whole ShellBar is basically blank. This also happens if I start PWB with a batch file. All of the other settings I've configured in the INI file show up correctly.
If I start up PWB with a desktop shortcut or by opening the .exe directly, the links show up. Any idea what causes this?
Use the full path to the Shellbar folder in your INI file. This will help PWB locate the folder when it starts from a batch file.
