what's new in version 2.10.4?
mbhamp
Post by mbhamp »
I'm about to configure a new public image. My last tested version was 2.10.2 and not so sure I want to upgrade unless reason to...
Here are the changes from PWB v2.10.2 to the about to be released v2.10.5.
Version 2.10.5 08-xx-2008
Fixed/Changed:
Ctrl+ Increases Zoom level, Ctrl- decreases Zoom level.
Fixed pop-up windows sizing when sizing diabled.
Fixed Shutdown/Restart/Logoff options for XP SP3.
Changed load order of toolbar icons.
Added: (These settings are added but hidden until PWB v2.11 is released)
Added [Browser] MaximizeOnNonSizable=False Maximizes window when page sets non-resizable.
Added [Java] JavaClose= Closes PWB with bypass for disable exit and restart on close.
Added [Java] JavaStartApp= Starts application in new process.
Added [Files] ExecuteOnDenyAccess= Executes application with URL (%1), and access string (%2) as arguments.
Added [Files] ExecuteFilterFile= Filter file for CheckExecuteAccess execute on deny access.
Added [Security] CheckExecuteAccess=False Checks URL access and executes application.
Added [Security] PreventFileDownload=False Prevents non-active files from downloading.
Added [Browser] DisableImageSizing=False Disables image resizing when image file is bigger then window.
Added [Browser] SecureMode=False Starts PWB in an alternate Windows Desktop.
Added [SecondWindow] ForceToFront=False Forces all child windows to front if main window has focus.
Added [Files]LastGoodURLFile= If set to file path PWB will write last "good" url to the file.
Added [Buttons] Zoom=True Enables Zoom button.
Added [MenuItems] ViewZoom=True Enables Zoom menu
Added [MenuItems] ViewZoomIncrease=True Enables Zoom Increase
Added [MenuItems] ViewZoomDecrease=True Enables Zoom Decrease
Added [MenuItems] ViewZoomLarge=True Enables Zoom Large (200%)
Added [MenuItems] ViewZoomNormal=True Enables Zoom Normal (100%)
Added [MenuItems] ViewZoomSmall=True Enables Zoom Small (50%)
Added [MenuItems] ViewZoomCustom=True Enables Zoom Custom
Removed:
Version 2.10.4 03-31-2008
Fixed/Changed:
Fixed error if PWB is started and then close quickly.
Fixed error if Show Address Bar is set to false and not title bar is showing.
Fixed http://www.zillow.com not searching twice by having PWB remove ZillowMap.swf from cache before navigation.
Fixed issue when set to always on Top and other application is clicked while starting preventing always on top.
Removed:
Version 2.10.3 02-05-2008
Fixed/Changed:
Fixed HTTPS support in IP filter when -all is set.
Fixed Problem with Windows XP SP2 Security Feature loading.
Fixed Release document when clsoing PWB Windows with non-HTML document loaded.
Changed includes support for XP SP2 and IE7 advanced features and security.
Changed ignores About:Blank when [Browser]StartTimersOnMouseKeyboard=True
Changed UNC path INI files are copied to a temporary local file before parsing to speed loading.
Changed Scaling of image files in browser window with click to enlarge support.
Changed JAVA_PLUGIN_WEBCONTROL_ENABLE set to TRUE when starting.
Changed Exit script will run even if PWB is closed by overrides.
Changed About:Home to navigate to PWB home page instead of IE home page.
Added [Browser] MaximizeOnNonSizable=False Maximizes window when page sets non-resiable.
Removed:
[Java]JavaPrintFrame Not used often but causes problems with long URL addresses
[Java]JavaFillElement Not used often but causes problems with long URL addresses
