Remote Desktop & the kiosk exit
pwindsor
Post by pwindsor »
I use Remote Desktop to install and make adjustments to the ini files etc. We have a shortcut in the startup menu on the stations where we use PWB, so when I connect via remote desktop PWB is already launched and in kiosk mode. I can't get out of it with the Ctrl/Alt/Shift/Insert because that command won't go through Remote Desktop connections. I found some alternate combinations that work for standard keyboard shortcuts, but not this specirfic one for PWB. Any suggestions?
Unfortunately the key combination is currently the only way to display the overrides dialog.
We will add a secondary combination to PWB v2.10.6 beta.
The following was added to PWB v2.10.6 B (beta) currently available on the Beta Downloads web page.
http://www.teamsoftwaresolutions.com/betadownloads.html
Added [Security] EnableAlternateOverrideKeys=False Enables Ctrl+F4 to open override dialog.
This is the currently the only change from the release version of PWB v2.10.5 so you should not have any problems with it.
