MSI installer for version 3
Posted: Mon Jul 16, 2012 2:56 am
by SaLSouL
Hello,
Will there be an MSI version made of V3 PWB for deployment via gpo ?
regards
Sal.
Posted: Mon Jul 16, 2012 1:22 pm
Eventually.
However PWB does not need to be installed. Since PWB is fully self contained, copying the PWB folder from computer to computer is all that is needed.
Posted: Tue Jul 17, 2012 1:58 am
by SaLSouL
Scott wrote:Eventually.
Thanks for the reply scott, I have done just that in the event of there not being one available..
thank you
Posted: Tue Jul 17, 2012 4:09 am
by SaLSouL
Hi scott,
Ive also just noticed there is no longer these settings in PWBv3.ini file
PWBv2.ini
[ScreenSaver]
EnableScreenSaver=True
ScreenSaverSeconds=180
EnablePolicyScreenSaver=False
PolicyScreenSaverSeconds=10
DisableScreenSaverOnPolicyClose=False
DisableScreenSaverOnClose=False
WindowsScreenSaverExe=
WindowsScreenSaverMinutes=3
can these be simply added to PWBv3.ini and will still function ?
kind regards
Sal.
Posted: Tue Jul 17, 2012 9:36 am
The functionality would need to be added to PWB v3 in order for the INI settings to work. We are building on the basic version of PWB version 3 and adding functionality as it is needed.
The screen saver settings would normally only be used when running PWB as the Windows shell. Using HideGUI is a much better way of running PWB as the only application and when using HideGUI you can use the Windows Policies to control the screen saver.
