Install/uninstall process
Posted: Wed Nov 21, 2012 10:45 pm
I see the install process is very basic, but given that this is intended to be run as an application, why is it not using the Windows install process so that it can be 'officially' uninstalled when necessary?
I am running Windows XP Pro SP2 in a vitual environment as test bed. But will deploy into a real Windows XP Pro SP3 system when I have this setup the way I want.
This may be related to another issue I had. when I initially installed this in my Virtual test environment, and started PWB.exe, it caused the Windows 'Open File - Security Warning'. I had to open properties and Unblock the program to avoid the warning.
