PWB v3 CEF
Posted: Fri Aug 29, 2014 11:09 am
PWB v3 CEF (Chromium Embedded Framework) uses the Chrome HTML rendering engine instead of the IE rendering engine thus it does not suffer from the IE compatibility issues of IE.
Unlike PWB v3 IE which uses the installed version of IE on the computer, PWB v3 CEF is distributed with CEF and there is no need to install Chrome, unless any sites that need to be navigated to uses any Chrome plug-ins such as Flash.
Because PWB v3 CEF is distributed with CEF and it does not use the local copy of IE installed on the computer, it is recommended when using a shared installation only the INI and secondary files such as the URL filter file, be accessed from a shared network location. Network latency can cause inadvertent connection and rendering issues.
