Hide Second Lower Toolbar?
Posted: Mon Apr 13, 2015 11:55 am
by FPLD
I'm exploring moving to V3 using Chrome, but when I use my existing INI upgraded to V3, I see a second lower toolbar displaying a drop down and new tab icon. I've figured out how to remove the two icons but not where to disable/hide the second lower toolbar. Any ideas what setting would do this?
Re: Hide Second Lower Toolbar?
Posted: Mon Apr 13, 2015 2:50 pm
Try setting the following in your INI file.
ShowToolbar=False
Please note, PWB v3.04.2 RC (Release Candidate) available on the Downloads page fixes a few issues with the toolbars.
Posted: Mon Apr 13, 2015 4:25 pm
by FPLD
Thanks Scott, that did it.
Another issue I've encountered is not being able to access a drop down menu on a web page with the mouse. If I click on the drop down menu, it becomes active/highlighted and I can cycle through the menu options with the keyboard arrow keys, but the drop down menu never appears.
If I use the default v3 ini file to access the same webpage, the drop down menu works normally with the mouse.
Would you know what setting could effect this?
Posted: Mon Apr 13, 2015 8:34 pm
There is a bug in the Chrome engine that prevents the drop downs from showing when you have [Browser]AlwaysOnTop=True set in the INI file. When always on top is true the drop downs appear behind PWB.
Setting the following will fix it.
AlwaysOnTop=False
[SecondWindow]
AlwaysOnTop=False
http://www.teamsoftwaresolutions.com/fo ... f=8&t=3011
