Library web page URL Links not working
Posted: Thu Jun 11, 2015 1:01 pm
by tbrown736
Need some help, please. Some, not all of our external links, we access via our Library Home page, are not getting any response when we click on the links or select a linked URL within a menu. The only settings I adjusted in the .ini file was to disable the address bar and set the window size. did I missing something else?
Re: Library web page URL Links not working
Posted: Thu Jun 11, 2015 1:23 pm
What version of PWB v3 are you using including the minor revision number and rendering engine, for example version "3.04.2 CEF".
What is the URL of the web site exhibiting the issues?
Posted: Thu Jun 11, 2015 1:48 pm
by tbrown736
The version in your example is the one, we're using. most of the links embedded in '
http://www.bellwoodlibrary.org/index.ph ... -resources' are not responding in the public browswer.
Posted: Thu Jun 11, 2015 2:54 pm
It looks like many of the links on
http://www.bellwoodlibrary.org/index.ph ... -resources open new tabs, do you have new tabs or new windows disabled?
DisableNewWindow=True
DisableNewTab=True
Posted: Thu Jun 11, 2015 2:55 pm
If you use a stock unedited INI file, do the links work?
Posted: Fri Jun 12, 2015 11:07 am
by tbrown736
Yes, those two items were disabled in the .ini file. The links are working now. Thank You.
