Not able to auto launch DOCX files using the Execute Filter
Posted: Tue Jan 16, 2018 8:30 am
by Rockhard
We are unable to launch any DOCX files, when we have the Execute Filter enabled.
We are able to execute the DOC files, but not the DOCX files. Please advise how we can have the DOCX files auto execute.
In the Excecute file we have the following defined:
!application/msword
!application/x-msword
!application/vnd.openxmlformats-officedocument.wordprocessingml.document
!application/vnd.openxmlformats-officedocument.wordprocessingml.template
!application/vnd.ms-word.document.macroEnabled.12
!application/vnd.ms-word.template.macroEnabled.12
Re: Not able to auto launch DOCX files using the Execute Filter
Posted: Tue Jan 16, 2018 12:14 pm
Do you have an example of a link that uses the DOCX format?
Posted: Tue Jan 16, 2018 1:35 pm
by Rockhard
the link is only on our Intranet. But it could be any DOCX file. Even in an email
Posted: Thu Jan 18, 2018 10:25 am
It seems to work as expected using your Execute file and the following link as an example:
https://www.teamsoftwaresolutions.com/docx/test.html
From the History File:
TSSWKS99 1/18/2018 11:16:08 AM <a!> application/vnd.openxmlformats-officedocument.wordprocessingml.document
Did you enable the Execute filter?
CheckExecuteAccess=True
Posted: Fri Jan 19, 2018 11:04 am
by Rockhard
We seem to be using a Joombla back end that has these files stored in a remository and the user clicks on download from there.
That is where the issue seems to be with Execute for DOCX files. The DOC files downloaded from the remository seem to open file through the PWB using the Execute filter.
Posted: Fri Jan 19, 2018 12:20 pm
Without being able to test it directly it will not be possible to give you the information for the execute filter. However you should be able to use the history file to determine what to put into the execute filter file.
WriteHistoryFile=True
TrackURL=True
LogAccess=True
Posted: Mon Jan 22, 2018 7:24 am
by Rockhard
Got it working.
It was
!application/force-download
