ShellBar Problem
jace
ShellBar Problem
Post by jace »
I have found a bit of an issue with the shellbar... It seems to fail to load properly when the PWB is called from another source.
Set up the ShellBar with an Icon shortcut in the folder and run PWB from a shortcut, the ShellBar works just fine...
However, if you click Start -> Run -> and type 'www.google.com' a PWB window will open, but none of the shellbar icons show up.
This is an issue currently for me because I have a web page embedded in the desktop (An actual use for Active Desktop? Who knew! :-D ) and the windows that are created from that fail to have the shellbar icons I have set up.
Any ideas on how to take care of this would be greatly appreciated.
You should use the full path to the shellbar folder. When PWB is launch from another application the current folder will not be correct and PWB may not be able to find the shellbar folder.
