PWB version 3.05.8 CEF/IE Released
Locked
PWB version 3.05.8 CEF/IE (05-27-2020) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.8 05-27-2020
Fixed/Changed:
Changed to CEF 4044 Chrome 81
Fixed User Agent Filtering
[Files]UserAgentFilterFile= Filter URL to set User Agent
Removed:
Locked
