PWB version 3.05.10 CEF Released
Locked
PWB version 3.05.10 CEF (05-07-2021) has been released and includes the following changes. See the "ReadMe.txt" file for complete change history.
Version 3.05.10 05-07-2021
Fixed/Changed:
Updated to Chrome 89
Fixed [Security]OnlyAccessInternet=True not allowing PDF file to be viewed.
Removed:
Locked
