PWB version 3.05.11 Released
Locked
Version 3.05.11 11-10-2021
Fixed/Changed:
Fixed crashing when closing under certain circumstances.
Fixed confirm close when Javascript self.close() is used in tab.
Changed User Agent for Google sites.
[Browser]UseRAMCache=False Uses RAM for cahce instead of hard drive
[Printer]CheckPrinterAccess Enable Print URL filter
[Printer]CheckPrinterFile Filter file for Print filter. +/-URL to allow printing. Similar to the URL filter
[Printer]CheckPrinterMessage HTML formatted message shown when printing is blocked.
Removed:
Locked
