Account information auto filled in
Posted: Thu Jun 30, 2022 10:43 am
by cooperf01
Is there a way to fill in the information needed for login to a specific web page automatically so all the have to do is click log in.
- 2022_06_30_12_39_57_Clipboard.png (11.75 KiB) Viewed 109862 times
Re: Account information auto filled in
Posted: Fri Jul 01, 2022 8:44 am
See this topic in the forums "PWB CEF Autologin to a Site":
viewtopic.php?f=8&t=3652
Posted: Tue Jul 05, 2022 7:14 am
by cooperf01
I have tried that but it does not seem to work. This is the URL for the site
https://seminolestate.campus.eab.com/se ... irect=true and I added the signinfilter.txt to the end but it does not work.
Posted: Tue Jul 05, 2022 10:15 am
If the following values are not present, add them to your INI file.
JavaScriptFilterFile=signinfilter.txt
CheckJavaScriptAccess=True
In the filter file (signinfilter.txt):
-all
+^https://seminolestate.campus.eab.com/session/new signinjavascript.txt
In the JavaScript file (signinjavascript.txt):
document.getElementById('login').value='john';
document.getElementById('password').value='letmein';
document.getElementsByName('commit')[0].click();
The filter file has PWB analyze each URL, specifically for one that starts with "
https://seminolestate.campus.eab.com/session/new", and when it matches inject the JavaScript from the "signinjavascript.txt" file.
This will fill in the "login" element with "john" and the "password" element with "letmein" and then click the "commit" element.
- javascript_example.PNG (54.26 KiB) Viewed 109841 times
Notice we had to use the get element by name in the second command as the "commit" element does not have an ID.
Posted: Tue Jul 05, 2022 10:16 am
Here are the files we tested with.
Posted: Tue Jul 05, 2022 12:06 pm
by cooperf01
Thank you.
Posted: Wed Jul 10, 2024 9:08 am
For those wanting to suppress the "Manage Cookie Preferences" when using the III Vega catalog and the PWB Clear Cache on Close, attached are the filter files to do it.
