PWB version 3.05.15 Released
Locked
Version 3.05.15 10-31-2022
Fixed/Changed:
Updated to Chrome 106
Fixed cache not resetting on restart
[Browser]UseRAMCache=False Uses RAM for cahce instead of hard drive
[Printer]CheckPrinterAccess Enable Print URL filter
[Printer]CheckPrinterFile Filter file for Print filter. +/-URL to allow printing. Similar to the URL filter
[Printer]CheckPrinterMessage HTML formatted message shown when printing is blocked.
Removed:
Locked
