How to disable Ctrl-C, Print Scren
Posted: Wed Mar 11, 2026 5:52 pm
by petefink
Hi, I'm pretty new to PWB and have searched the settings PDF/forum posts, but cannot find a setting for disabling the keyboard commands for Cut/Copy and Print screen (aka disabling the clipboard).
My example is that I can highlight a block of text, press Ctrl-C, exit PWB and then paste the question into Word. I do have the Cut/Copy/Paste buttons disabled in the INI file but the keyboard functions still work.
Thanks for any suggestions. -Pete
Re: How to disable Ctrl-C, Print Scren
Posted: Thu Mar 12, 2026 8:41 am
The easiest way is to enable the clear cache on close. This will not only clear the cache, it will also clears the clipboard when PWB is closed.
ClearCacheOnClose=True
The Print Screen button is a Windows function and would need a secondary application, however disabling the buttons and menu items in the PWB INI file should prevent the keyboard shortcuts, but we will look into it.
Posted: Thu Mar 12, 2026 3:22 pm
by petefink
Thank you! That worked, and also blocked the print screen image too.
