I keep get the message
The publisher could not be verified. Are you sure you want to run this software?
Name PWB.exe
Publisher: Unknown Publisher
This happens with v 2.05 r3, on WinXP with SP2
I know I could remove SP2 and it should work fine, but is there anyway I can correct this? Maybe with group policy or something?
Publisher could not be verified
Laguz
unblocking
I tried this and it didn't seem to make a difference (it still asked every time I ran the program), though that may have to do with the security we have setup. I will have to look into it more.Uncheck the box that says "Always ask before opening this file".
We are running it off a Win2000 server. I didn't see that option on the server. Also is there anything I can do to automaticly take care of it on every PC, instead of hitting every pc in the building?Or:
Right-click the PWB.exe file, select properties. On the general tab, click the unblock button.
Laguz
Solved
OK! I got it fixed.
When I first tried to click the unblock, I was doing it from the server itself (where we run PWB.exe from), which is Win2k and does not have that option.
When I came in this morning, I tried it again by browsing to the file from my WinXP machine, with SP2. Sure enough, the button was there, so I clicked it and clicked ok.
It must have changed the actual attributes of the file, because when I went to a different PC that was having trouble before this, it worked fine, without prompting. I tried a second PC to be certain and it was ok there.
So making that change on the server file, cleared it for all the PCs.
Some interesting reading on the subject.
http://mikedimmick.blogspot.com/2004/08 ... -file.html
http://www.microsoft.com/resources/docu ... l_xurt.asp
http://www.diamondcs.com.au/index.php?p ... fs-streams
