Having a problem with a form
jnowak
Post by jnowak »
Hello. My company currently uses Public Web Browser over Citrix. We're using it to restrict access to a web based piece of financial software due to security issues. It works great for everything except processing reports. What happens is when you click on the print button, it pops up a second window that basically freezes the whole browser. After about a minute, this message pops up on the parent browser.
"A script on this page is causing Internet Explorer to run slowly, your computer may become unresponsive. Do you want to abort the Script?"
Javascript is definetly enabled, and if I run it in straight IE it works just fine. I have tried bypassing citrix and running it locally over PWB from my machine with the same results.
My URL access file looks like this:
+http://kratos/*
+javascript
+About:Blank
-all
-C:\\
I also have the history file turned on, but I'm afraid I don't really know what <t> and <a+> mean. Anything else I can provide to help, I will. Thank you.
If you disable the URL filter does it work?
Do you have the IP filter enabled?
Here is a list of the codes.
http://www.teamsoftwaresolutions.com/ph ... .php?t=195
jnowak
Post by jnowak »
URL Filter is disabled
IP Filter is disabled
And according to the history file, all looks good in the history file.
Does it work as expected if the filters are disabled?
