INI from a webserver problems
James
Post by James »
I'm using 2.08 and trying to use an INI from a webserver. When I click my custom shortcut, I get the error box:
The wrong version of INI file or Registry settings was used.
The INI is returning as the version. This version of PWB requires version 2.08 of the INI file.
Check your INI file or Registry and try again
Then crashes when I click OK.
However, it does download the proper INI file which shows:
IniFileVersion=2.08
Any idea why it doesn't recognize the version number? (By the way, I disabled checking the version in the INI file itself.)
James
Are you specifying both the command line INI options?
…\PWB.exe /INI=”Other.INI” /URLINI=http://www.web.com/PWB.INI
If you do not have the "/INI" switch it may cuase this type of problem.
James
Post by James »
Yes, here is the command line of my shortcut:
"C:\Program Files\TeamSoftware Solutions\Public Web Browser v2\PWB.exe" /INI="internet.INI" /URLINI=http://www.seminolecountyfl.gov/lls/lib ... /xxxxx.INI
It does create the internet.INI file before crashing.
James
Try changing the /INI="internet.INI" to the full path to the file.
For example:
...PWB.EXE /INI="C:\PWB\Interent.INI" /URLINI=...
The error message indicates PWB is not finding the INI file specified in the command line.
"The INI is returning as the version. This version..."
Normally this will read:
"The INI is returning 2.07 as the version. This version..."
James
Post by James »
That fixed it. 8)
Thanks a lot, Scott!
James
