Interesting alternate to the Shellbar.
Here is a sample of using JavaScript to display a floating shellbar using the PWB external java commands.
http://www.teamsoftwaresolutions.com/beta/shellbar.htm
Set the following in your PWB INI file to allow the PWB java commands to open the application with this sample.
[Java]
EnableExternalJava=True
JavaExecute=PWBExecute
To prevent others from using the PWB java commands to launch applications, change your PWB JavaExecute command keyword.
