Limiting a user to one site.
Use the PWB URL filter to allow only a specific web site.
Eable the PWB URL filter by setting the following in the INI file.
CheckURLAccess=True
CheckURLMainFrameOnly=True
Edit the URL filter file listed in the following INI key to allow only the one domain.
CheckURLFile=URL.txt
For example to keep PWB on the TeamSoftware Solutions web site, put the following in your URLs filter file.
-all
+JavaScript
+About:Blank
+https://www.teamsoftwaresolutions.com
This would keep PWB to only URLs that contain "https://www.teamsoftwaresolutions.com". If you want to get even more restrictive, use the regular expression begins with to only allow URLs that begin with https://www.teamsoftwaresolutions.com.
Here is a link to a post that discusses the PWB filters.
http://teamsoftwaresolutions.com/phpBB2 ... c.php?t=13
wgragg
Re: Limiting a user to one site.
Post by wgragg »
Thanks Scott. That worked.
