odd pop-up behavior
amutch
odd pop-up behavior
Post by amutch »
We have a link on a web page that is supposed to call a javascript function to open a new window. This works in IE even when the highest level of pop-up blocking is enabled. But in PWB (2.09.3), it generates a blank window. The odd thing is that if you do a right-click on the link that calls the function, it will open correctly in a new window (select open link in new window if you get a context menu). The link is located on this page:
http://twp.waterford.mi.us/gis/
click on the globe image as this in the link that calls the javascript function.
Andrew
There does seem to be a problem. I am looking into it.
amutch
Post by amutch »
Thanks Scott.
Here is what we have found so far.
The function in the web page is resizing the new window.
function newMapWin() {
  newWaterfordTwpWin=window.open("","WaterfordTwpMapWindow","toolbar=no,location=no,status=yes,resizable=yes");
  var scrWidth=[b]screen.availWidth[/b];
  var scrHeight=[b]screen.availHeight[/b];
  [b]newWaterfordTwpWin.moveTo[/b](0,0);
  [b]newWaterfordTwpWin.resizeTo[/b](scrWidth,scrHeight);
  newWaterfordTwpWin.document.location="http://maps.twp.waterford.mi.us/Viewer.htm";
The Internet Explorer web browser control PWB is using does not seem to support this in a new window.
However PWB does support it in the same window. Changing the code to the following works.
function FullWindow()
  var scrWidth=screen.availWidth;
  var scrHeight=screen.availHeight;
  top.window.moveTo(0,0);
  top.window.resizeTo(scrWidth,scrHeight);
As a work around you can have the new window open to the map page and have the map page resize the browser.
We are looking for a fix correct the problem directly.
amutch
Post by amutch »
Thanks. I'll look at modifying our code. We've also added an alternative link for people with pop-up blocking enabled that might avoid that problem. I haven't had a chance to test that out on PWB but that might be a workaround for us as well.
Andrew
