Alternate INI problem and solution
robway
Post by robway »
When attempting to use the command line:
"C:\Program Files\TeamSoftware Solutions\Public Web Browser v2\PWB.exe" /ini="anyfilename.ini"
Returns the error:
The wrong version of II file or Registra setting was used.
The INI file is returning as the version. This version of PWB requires version 2.09 as the INI file.
Check your INI file or Registry setting and try again.
I get this error if I use the default pwb.ini as an alternate ini file, but it works just fine if I leave off the /ini= switch, so I really don't think it is the format of the INI file.
As I was typing this I had a thought and put the full path to the Public Web Browser folder in with the alternate INI file name switch:
"C:\Program Files\TeamSoftware Solutions\Public Web Browser v2\PWB.exe" /ini="C:\Program Files\TeamSoftware Solutions\Public Web Browser v2\anyfilename.ini"
and this worked.
Rob
Thank you for the information. I will see if we can fix the problem in the next release.
