Full Paths in the INI
Full paths should be used in the INI [Files] section.
Default:
PolicyFile=.\Policy.txt
Should be used:
PolicyFile=C:\Your Path\Public Web Browser v2\Policy.txt
The default is to use the relative path, but a better practice is to tell PWB the locations of the file. When using the relative path ".\" if the current Windows folder changes PWB will no longer be able to find the files it needs. Using full paths to the files in the INI file will ensure PWB is able to find the files.
