Good morning,
Would it be possible for someone to show an example of
the TProxyChoice v1.01 using a list of sites and keywords. We
would like to be able to use this feature as an on/off switch but
are unsure of how to set it or if it is feasible.
Thanks, George
using TProxyChoice v1.01 with list
TProxyChoice can be used to start PWB with either the Proxy Enabled or Disabled when the respective button is pressed. It does not attempt to determine the proxy setting based on a URL. Basically TProxyChoice edits the registry and invokes the browse of choice when the button is pressed.
PWB v2.05 has a Proxy override that can toggle the proxy on or off.
