This problem does not happen in Internet Explorer. It doesn't happen in the beta version of 2.05, but it does happen in 2.05 final and 2.04v4.
The error that pops up is "A runtime error has occured, do you wish to debug?" and it says the error is "Object doesn't support this property or method". When I debug, the runtime error happens on a line that states "simwindow.Playsomething();". The somthing depends on what chapter I am trying to open.
This error happens when running the Microsoft Interactive Training for Microsoft Office XP (MIT). When MIT opens to the home page, which has a table of contents, A browser window pops up with animated graphics and various controls (play, pause, next chapter, etc...). This windows is playing the intro on how to use MIT. If I close this animated window and then double-click on a chapter in the table of contents, this animated window should pop up again and play that chapter.
This works fine in IE, and 2.05 beta. In 2.04v4 and 2.05 final, the first animated windows opens fine, but once this window is closed, clicking on any of the chapters causes the error.
Any ideas? Am i just stuck using the 2.05beta?
Thanks much,
Jason
Problem in 2.05 final was also in 2.04, but not 2.05 beta
Jason Weinstein
Eugene Public Library
Eugene, OR
Eugene, OR
Is it possible to save enough of the pages to simulate the problem on a computer without using the CD? If so, could you zip the files and send them to Support@TeamSoftwareSolutions.com so I could do some testing with them.
Or is this tutorial available on the web somewhere?
