If you are using PWB v2.06 with the Clear Cache on Close setting, you may receive inconsistent results when the home button is pressed, or the home action is taken in the timers.
You may want to set Clear Cache on Close to false if you are using PWB v2.06 and are experiencing problems.
If anyone is having this problem please let me know so we can gauge the problem and get it fixed.
PWB v2.06 Clear Cache on Close
We are now publically beta testing PWB v2.06 revision 2. This revision fixes a problem with pop-ups locating off the screen, and a problem with the clear cache on home setting.
http://www.teamsoftwaresolutions.com/beta/PWBv206r2.zip
