Shell Bar Icons
rheckber
Shell Bar Icons
Post by rheckber »
Thanks for all the work on the shell bar since the earlier versions but I have one question. Is there anyway to completely eliminate icons on the shell bar and have it just text?
I tried a size of zero but that just shows it at the default size of 22.
GregP
Post by GregP »
It would still leave space for the icon, but you set a blank icon.
Depends on the look you want.
GregP
Set the icon to a blank as GregP mentions, and set the shellbar icon sizes to a 1. PWB assumes if the icon sizes are zero it should use the default size.
ShellButtonIconWidth=1
ShellButtonIconHeight=1
Instead of using the shellbar, you could use the shell button and have the shell applications on a drop down menu.
