I have tried both PWB 2.0.5 and the most recent version of 2.0.8 and they both have this problem. I have set up a computer that will only be used to access our library catalog.
I have PWB set to exit after 3 minutes of activity and have it set to reopen after it is exited. Most of the time PWB closes, opens and loads our catalog page without any problems. But sometimes (about once a day) upon reopening, PWB gets stuck as Not Responding.
The page that PWB is loading is: http://140.211.82.133/Polaris/Search/Po ... ageid=1033
The computer is running Windows XP SP2 and McAfee Enterprise Anti-virus.
Any ideas?
Jason
PWB Not Responding when loading our Catalog page
Jason Weinstein
Eugene Public Library
Eugene, OR
Eugene, OR
Jason,
Try setting the following in your INI file to see if it clears up the problem.
ClearCacheOnHome=False
ClearCacheOnClose=False
The problem may be caused by PWB trying to restart when it is still clearing the cache files. We are taking steps in PWB v2.08.1 to avoid this potential problem.
I have changed both of those settings in the ini, but PWB will still open up and get stuck not resonding. Generally when this happens "Web site found. Waiting for reply..." is in the status bar. Once I try clicking on the window a couple of times "(Not Responding)" shows up in the title bar.
I can also replicate the problem by using a program similar to AutoRestart to open PWB whenever it is exited. I then just exit PWB a few times and after a few tries a PWB window will open not responding.
I can not replicate the problem in IE.
- Jason
- Jason
Jason Weinstein
Eugene, OR
Eugene, OR
