Greetings,
Is there a way to use gpedit once, then have its settings be applied to an entire domain of PCs running Windows XP? Our server software is OLD, Win NT 4.0. Do we need to be running Windows Server 2003 or Windows Server 2000 to have a group policy be applied to the entire domain?
We're tired of having to use gpedit on each PC individually!
JP
Applying Group Policies to Entire Domain
Jeff Papier
Senior Network Librarian
Monmouth Junction, NJ 08852
The easiest way to deploy Group Policies would be via an Active Directory. Of course if you have an NT 4.0 domain, upgrading your Domain Controller would be a chore in itself.
In your case you may want to check out the SECEDIT tool. SECEDIT is a command line tool used to deploy security templates.
Here are some useful links.
http://www.microsoft.com/resources/docu ... pnode.mspx
http://www.microsoft.com/resources/docu ... _cmds.mspx
http://techsupt.winbatch.com/TS/T000001036004F29.html
