inactivity reboot not working
We just upgraded from v2.4 to 2.08r4.
We have some "express" computers that reboot after two minutes of inactivity.
We see two problems since the upgrade:
1. the inactivity timer gets reset every once in a while -- I suspect from our catalog page (catalog.mppl.org). Any way to stop that?
2. When it does reach inactivity it does not reboot.
Please help!
listed below is our INI file...
[Edited for brevity]
Please help!
reboot problem
We use Win XP Pro -- with all of the critical updates loaded.
						Does the user have enough authority to reboot the computer?
There are some Windows Policies and security settings that will prevent the user from rebooting the computer. If the user does not have enough authority to reboot the computer that is logged on when running PWB, the comptuer will not reboot via PWB.
NOT rebooting
The user has administrator access.
						The inactivity dialog does appear -- but no reboot after.
We tried other actions including restart and execute and they work.
So as a work around we executed a BAT file that had a "shutdown -r" command and that works.
So now our problem is that the inactivity timer seems get trigged by something our catalog (http://catalog.mppl.org) is doing. Also -- it seems to start as soon as the browser starts -- not after someone uses it.
(we have InactivityStartOnOpen=False in the INI)
Any ideas?
Any ideas?
Starting out at the following URL.
Redirects to the following URL.
http://catalog.mppl.org/uPortal/Initial ... aram=props
The redirect causes PWB to start the timer. You can get around this by setting the home page to the redirected to page.
This will result in one navigation and PWB will not start the timer.
The page is refreshing every 6000 seconds.
From page source:
<META http-equiv="REFRESH" content="6000;...
This will cause the PWB inactivity timer to start when the page is refreshed and reboot when the inactivity timer expires.
You will need to change the page to prevent it from refreshing in order to not start the PWB inactivity timer.
						From page source:
In the current version of PWB there is not a way to ignore this, but I can certainly add it.
In fact here is PWB v2.09 with this functionality added.
http://www.team2s.com/beta/PWBv209.zip
IgnoreHomePageRefresh=True
Please let me know if you have any questions.
Your home page is refreshing to a different URL, and setting the home page to this other URL causes a web page error. If the page simply refreshed the Ignore Home Page Refresh would have worked.
PWB v2.09b has been reposted to the beta page. We removed the following.
and added the following.
StartTimersOnMouseKeyboard=True
This seems to make more sense then the Ignore Home Page Refresh and does seem to work on your catalog page, even when starting from http://catalog.mppl.org.
To ensure you have this version, the date indicated in PWB should be dated at least 11-07-2005.
Please let me know if this works as expected.
