PWB crashing
- Contributor
PWB crashing
I hope you all can help. It just started yesterday. We are using PWB 2.0.8 IE6 Win Xp SP2. Whenever you open it up you get our home page but when you go to navigate to a page t crashes. I've ran spyware, antivirus scans with multiple programs and it is still doing the same thing.. Anyone else have this happen??
- Contributor
- Contributor
If IE crashes then PWB will crash because PWB uses IE for all its HTML rendering, try re-installing IE.
I will see what I can do about using the Gecko engine Firefox uses instead of IE. There was a point in time that PWB v1 could be used with either the IE or the Gecko engine and 99% of the people used the IE engine so we took out the Gecko support to simplifiy and streamline the PWB development.
- Contributor
It's happening again. I did a re-install of Windows and set-up the machine with the newest version of PWB. I have the cache cleaned everytime someone logs off. Selected option to empty temporary internet files on close.
I only have Windows XP SP2 and PWB installed. Latest windows updates. The account is set to a User account.
Help !
Help !
Try using PWB v2.09.1 which will be released on 1-19-06.
http://www.teamsoftwaresolutions.com/beta/PWBv2091.zip
You will need to have PWB v2.09 installed and then copy the new EXE file over the old EXE file.
Also send a copy of your INI file to support@teamsoftwaresolutions.com and I will take a look at it.
The current plan is to have PWB v2.10 be able to use the Gecko (Netscape, Firefox) engine as well as Internet Explorer.
For testing:
Download and install the following:
http://www.iol.ie/~locka/mozilla/control.htm
Then add the following to the PWB INI file for PWB v2.09.1 beta.
UseGeckoEngine=True
However this is only an early test for the Gecko engine and may not work as expected.
For testing:
UseGeckoEngine=True
