Hello all
I am setting up PWB and everything is working fine except for one thing. I can not block users from attaching files in gmail. I have it blocked in hotmail and yahoo no problem with DisableFileUploads set to true. When attach a file is clicked, a browse window is opened, and for some reason the default location is on my server.
Any help would be great
PWB and Gmail
Unfortunately GMail uses non-standard code for the Choose File dialog and the PWB disable file upload will not prevent it. We are however testing a new add-on to PWB that will close the File Open (Choose File) dialog if a web page tries to open it.
Here is the link if you want to test it.
http://www.teamsoftwaresolutions.com/be ... Browse.zip
If you test it, please let us know if it works as expected.
Tweraser Albert
