"Failed to create empty document"
jpapier
Post by jpapier »
Hello PWB-ers,
We have a few library catalogs still running some version of PWB 2.08, and
we want to upgrade them to 2.09.3. We ran the .ini updater program,
downloaded from this website, and converted the ver 2.08 pwb.ini to ver
2.09. Or so we thought. When we try to run the 2.09.3 version of pwb.exe with the new pwb.ini file, we get "failed to create empty document."
Can anyone (Scott!?) shed some light on this?
Jeff
Jeff Papier
Senior Network Librarian
South Brunswick Public Library
Monmouth Junction, NJ 08852
What is the command line you are using for PWB?
jpapier
Post by jpapier »
We actually invoked PWB just by double-clicking on its icon, right from the folder where all of the PWB files live. We did this just to test how things would work out before propagating the updated exe and ini files to the other OPACs. JP
Jeff Papier
What version of Windows are you using?
If you wouldn't mind, zip all the files together and send them to support@teamsoftwaresolutions.com.
jpapier
Post by jpapier »
Will do, Scott
Jeff Papier
Change the following line in your INI file to correct the problem.
ShellBarFolder=Shellbar
