I am having a problem with random sites giving me the access denied message.
I've turned on the Logging of Access errors and it isn't specifically logging these attempts. However, if I go to something that I know is blocked, the history shows a log of it being "A-" (blocked).
My URL.TXT contains:
+all
-C:\
-D:\
-E:\
+Z:\
+\\TSCLIENT\
+javascript:
+res://
+about:blank
But again, there isn't anything logging showing why this is being denied.
Random ACCESS denied problems
The PWB filters use regular expressions, and the backslash has special meaning in regular expressions. To use a literal backslash you need to precede it by a backslash. Change your file to the following.
+all
-C:\\
-D:\\
-E:\\
The "+all" option includes all URLs so you do not need to use any "+" when using the "+all" option.
To take is a step further to prevent access to the C:\ drive but not URLs that have "C:\" in them, add the begins with regular expression.
+all
-^C:\\
-^D:\\
-^E:\\
See the following thread for more information.
http://www.teamsoftwaresolutions.com/ph ... c.php?t=13
+all
-C:\\
-D:\\
-E:\\
+all
-^C:\\
-^D:\\
-^E:\\
