Certain sites seem to cause the PWB to crash. We recently updated the PWB in because it was said that this issue was corrected, but apparently not, or this is a different issue. We are a library environment and one web site that seems to crash a lot for some patrons is siDOTcom. First site, can't post web addresses on first post. It will never crash in the same spot, but does randomly crash, even when someone is just reading an article on the page. It won't crash on the same page, you just have to keep moving around the site, until it crashes which is completely random. We have the latest version of shockwave and flash installed. Anyone come across this or have any ideas. Also, their are other sites crash randomly too, not just si.
Chris, IT dept.
Rochester Hills Public Library
Latest Version of PWB Crashing
Did you mean the site: http://www.sidoticom.com/We are a library environment and one web site that seems to crash a lot for some patrons is siDOTcom.
We are just in the process of finalizing PWB v2.10.3. If you want, try running this version of PWB to see if the problem persists when using the site. If it does please send a copy of your PWB INI file to support@teamsoftwaresolutions.com.
To upgrade if you are using PWB v2.10.x and Windows XP SP2, simply download PWB from the link below and unzip the PWB.exe file and copy it over your current PWB.exe file.
http://www.teamsoftwaresolutions.com/beta/PWBv2103.zip
ChrisHearns
No problem, I just wanted to make sure. I will run some tests on http://www.si.com
Have you tried PWB v2.10.3?
ChrisHearns
We haven't tried PWB v2.10.3, but had just upgraded 2.10.2 thinking that would solve the problem. If you think 2.10.3 will solve the problem, I guess it's worth a shot. Still let me know if you find similar problems with SI.com wither either 10.2 or 10.3.
Chris Hearns, IT dept.
248 650 7128
248 650 7128
ChrisHearns
SI.com still crashing latest PWB
We have still had the same problem with PWB v2.10.3 SI still randomly crashes and I am thinking it may be caused by the advertisements on the site. They are constantly changing and if specific ones cause the crash, that would explain how random it is. I was wondering if anyone else has gotten si.com to crash on them or if there is any idea how to prevent future crashes.
248 650 7128
248 650 7128
ChrisHearns wrote:We haven't tried PWB v2.10.3, but had just upgraded 2.10.2 thinking that would solve the problem. If you think 2.10.3 will solve the problem, I guess it's worth a shot. Still let me know if you find similar problems with SI.com wither either 10.2 or 10.3.
248 650 7128
I have just spent the last 30 minutes on www.si.com and have not had any crashes using a stock INI file.
What version if Windows are you using?
What version of Internet Explorer is installed on the computer?
What version of Flash is installed on the computer?
Please send a copy of your current INI file to support@teamsoftwaresolutions.com.
