jfrasier:
Scott:When I was testing 2.10 by running the .exe and the .ini on a server I ran into problems, and it turns out that the 'server' I was using was really an XP workstation
You can put it on your main library server as an alternative. Of course if you have your one Windows XP web server, all the libraries may be able to get it from there as well. You may want to work with your Network Administrator to set this up. There may be a file server on your network that you can use to share the INI file from.I suggested installing Apache (a Free Web Server for Windows) on your current Window XP computer you are trying to use to share the INI file, as a means to get around the 10 connection limitation on Windows XP. This would incure no more bandwidth issues then you would have sharing the INI file through a Windows share, and would get around the 10 conneciton limitation on the same computer.
