Hello all.
Our library is going to use a website that starts in a popup made with flash. (not ours but stuff we need for visitors) This popup looks good in FireFox and IE but in PB it comes up way too small.
Screenshot Firefox
Screenshot Public Browser
Any idea how we can fix this??
Problem with size wanted POPUP
Hello Scott,Scott wrote:Is it possible for us to have access to the site so we can test PWB on it?
Don't think you can, afaik they check access through IP
The URL we use is:
http://netnieuws.bibliotheek.nl
Direct URL:
http://www.netnieuws.nl
Maybe there is a demo version for none customers, I can't see that because they redirect us.
Just checked, we're using 2.1.0.2 so gonna update now and see what happens...Scott wrote:What version of PWB are you using?
Without being able to test it directly, I would make sure you are using PWB v2.10.4 just to rule out bugs in previous versions.
Ok done. Unfortunately it didn't help
Will try to get you a login to the page.
EDIT: Just mailed you login info
Please send your INI file as an attachment to support@TeamSoftwareSolutions.com. I can take a look at it to make sure there is not a setting that may be causing the pop-ups to be small.
If you go to the following web site:
http://www.netnieuws.nl/netnieuws_out.asp
The "buttons" along the bottom ("abonnement netnieuws" ...) open pop-up windows, are these opening correctly in PWB?
Yes they do.Scott wrote:If you go to the following web site:
And will send you our ini file now.
Because we had an email exchange about this I forgot to reply here.Scott wrote:Thank you, this site does exhibit the problem with PWB. Try adding the following line to your INI file.
MaximizeOnNonsizeable=True
This seems to correct the problem on the test site.
For anybody else having the same issues with flash sites;
This last suggestion by Scott fixed the problem!
Thanks again Scott for all the great work
