Hello,
In our catalog, we give access to Syndetics content. With the first click, a window opens and provides links to the Summary, Cover Image, & Review content. If one clicks on the Summary link, another window opens up and there appears a PRINT button.
We managed to stop the Windows Print Dialog from opening after clicking the PRINT button by adding a portion of the image url to the URL.txt file, -print=yes.  The Print Dialog box does not appear and our access.rtf dialog box appears BEHIND the second Syndetics page.  If we allow the access.rtf file to time out while it is under the window, everything is OK. If we close out the second open window to see the Denial dialog box, then close out the Denial dialog page, the system crashes.
Have you ever run across this before?
Jeff
Lancaster PA
						Syndetics Summaries and PRINT buttton
				jsomerfield
 - Participant
				jsomerfield
 - Participant
http://syndetics.com/index.aspx?isbn=97 ... c=15083652
This link goes to the Syndetics page that has the PRINT button. Let me know if this is not what is needed.
Jeff.
Jeff.
				jsomerfield
 - Participant
				jsomerfield
 - Participant
