Inactivity Timer not resetting in certain application
bdearlove
Post by bdearlove »
Good Day,
We have the inavtivity timer working well and correctly except for one application. This one telnet type application (MEDITECH Workstation Client 4) does not detect mouse movements or keystrokes unless you move the mouse outside of the application window.
We are having issues with users working in this application then being logged off as the inactivity timer does not notice they are working in this application.
Has anyone run into this issue before? Thanks.
InactivityTimer=True
InactivitySeconds=6400
InactivityMessageTitle=Warning
InactivityMessageFile=Inactivity.txt
InactivityAction=Execute
InactivitySoundFile=
InactivityStartOnOpen=FALSE
InactivityShowDialog=FALSE
ResetOnMouseMove=TRUE
ResetOnMouseButton=TRUE
ResetOnKeyboard=TRUE
PWB can not detect mouse movements outside the PWB window. If there is an application in front of PWB, this can prevent the timers from being updated.
You can use the PWB idler available on the Downloads page to update the PWB timer when PWB does not have the focus.
bdearlove
Post by bdearlove »
Ah, perfect! Thank you very much!
